How much more for 12s?
Old Aug 21, 2004 | 01:20 AM
derek_silvy's Avatar
Nah, once I get my tune its track time. So, in 2 weeks I should be able to post an 1/8th mile time. That's the only local track, but I have one in my home town (1.5 hours away) that is the full 1/4th that I can go to once every couple months.
I figure I'm around 14 flat or so. That's just my guess.
Old Aug 21, 2004 | 01:24 AM
Deckhand's Avatar
Nitrous is for babies and its cheating huh?
I believe nitrous is the most efficient, best bang for the buck power adder available. It's cold (doesnt require intercooling), doesn't use crank HP to add power, and its puts down more power than most bolt on blowers can.
Old Aug 21, 2004 | 07:58 AM
Sport Side's Avatar
i agree. nitrous can put out some serious tq.
you talk about nitrous only being $600, but lets just see if it stops there.
Old Aug 21, 2004 | 08:55 AM
12sec.5.3's Avatar
I agree it is a very big bang for your buck. It's way too risky though. It's cheap for the kit, but when it goes wrong for some reason and blows your plastic intake to ****, and makes you a six inch cowl hood then you'll say, ''I should have never bought that ****.'' I've seen it happen.
It's your choice, but your truck will not hang with the rest nor last as long. My truck for instance is my daily driver, very streetable, reliable, and 103,000 on the clock and still going strong.
Old Aug 21, 2004 | 09:46 AM
I was scared of it too, but I see lots of people saying it's safe.
What kinds of mild head work did you have done? How much was that eaton?
Old Aug 21, 2004 | 10:02 AM
Flyer's Avatar
I'm thinking you need to get some track times and then tell us what we got to work with. A budget might also be nice too.
You could check out the fastest truck list and see what all the guys on htere have done.
Old Aug 21, 2004 | 10:04 AM
I can't wait to give you track times
Budget....
I'ld say that I could put another 2000 in it, but not all at once
Old Aug 21, 2004 | 10:09 AM
12sec.5.3's Avatar
It's a set of stock 5.3 heads. I shaved .020 off, put a 3-angle valve job, and slightly ported the exhaust and polished it to a shine. Barely even touched the intake side.(which i regret) And cleaned up the valve guides. That's it.
Old Aug 21, 2004 | 10:13 AM
12sec.5.3's Avatar
Good Idea
Old Aug 21, 2004 | 12:23 PM
Nitrous is a safe power adder as long as you take the proper precautions when putting it on. I have sprayed on 2 vehicles, and have helped install kits on a few of my friends cars, and we NEVER had a single problem with any of them. On my car I didn't even have all of the safety equipment that I should have(because I am crazy like that), I just made sure not to gun it under 3k and made sure I had enough fuel. I don't feel that it is cheating that much, but I can see why someone who has never used it would think so. It sure does suck when you run out in the middle of a good race though.
By the way, to hit 12's I would go with a 3k stall, 100 shot, and slicks. You should have no problem there.
