how much grinding to fit 15"s?
Old May 8, 2005 | 03:25 PM
VicRed's Avatar
Default how much grinding to fit 15"s?
How much grinding is need to fit a pair of 15" rims? From what I can remember its no too awful much. I just wanna know if it is gonna be enough to where it causes durability issues with the caliper/bracket.
Old May 8, 2005 | 03:35 PM
Green Thunder's Avatar
I dont know myself but I am wondering why you would want too?
Old May 8, 2005 | 06:37 PM
Yelo's Avatar
TRACTION
There are ALOT more (and cheaper) slick choices if you go with a 15" rim
Old May 8, 2005 | 07:41 PM
VicRed's Avatar
Originally Posted by Yelo
TRACTION
Old May 8, 2005 | 10:27 PM
TRACTION
2001 RCSB LS1 / TR224 / Jag Perf. 4L65 / Nelson Tune / One Wheel Peel
Surely something in a 16 would be ok wouldnt it?
Old May 8, 2005 | 11:05 PM
sleepersilverado's Avatar
i think it is quite a bit and i dont know if it will work but i thought someone had already done it. from what i remembered when i had a truck on the lift i looked at it and took a tape meassure to it and it looked like a lot.
Invest in an eaton posi
Old May 8, 2005 | 11:40 PM
LedFut's Avatar
14 Second Truck Club
Dude, Austin, get a posi first. THEN worry about grinding for slicks. You'll be amazed at how well that posi will help, even just a stock G80.
Old May 8, 2005 | 11:41 PM
F8L Z71's Avatar
Anyone know how much different the truck calipers are vs the F-body???
I had 15s on my T/A and if the grinding is about the same I'll do it again for this truck.
Lot's more choices for 15" slicks and there is more siidewall for better traction. :0
Old May 9, 2005 | 11:17 AM
white1's Avatar
I know for a fact it doesn't cause any issues, but I don't remember how much you have to grind off.
Old May 9, 2005 | 08:41 PM
ASkipper's Avatar
11 Second Club
Been there done that.I put 15" wheels on my 99 GMC Sierra.They were steel American Racing 15x8. I had to grind about 3/8 to 1/2 of an inch off.I put a 3/8 inch spacer between the rim and rotor.They fit great. I had about 1/4 inch of clearance between the rims and calipers.I also ran a set of 28x10.50-15 MT et streets.
