how much boost is safe to run in a stock 6.0?
with meth you can add timing due to the increase in Octane. I have no idea of what, if any gains Meth alone offers, I pullied down, increasing boost at the same time and have been using meth ever since.
There's a lot of info on the boards regarding the benefits of meth
I am not running meth but at WOT my a/f gets down to 10.2 ...I think this is a little on the rich side but works for now. I want to lean it out a bit to see if it gets a little more power.
I just drove home from work and I guess my memory just isn't what it used to be. 11.2 to 11.5 at WOT.
Terravast4, how much boost do you see with that 2.8 pulley and those heads?
30 is probably the coldest and probably only a week or two........but it will increace boost and i am looking at 12# in 105 degrees vs. 40-50 degrees in winter. Curious to see how much it changes
