How much boost can be run on a 6.0 with a radix?
14 Second Truck Club
Just Wondering. With the pullies available for the radix, how much boost would the smallest one put out on a 6.0 with the following:
-Long-tube headers w/free-flowing dual exhaust
-Electric Fans
-02' LS6 Cam or other blower friendly cam
-Custom Dyno-Tuning
-2600 stall
-3.73 gears
-slicks
-other "little things"- Ported TB, Free Mods, Descreened MAf, etc.
Also, How much power would this truck make at the wheels (HP & TQ)? What would it run at the track (assuming it was a single-cab step-side)?
Would be a pretty cool truck huh?
-Electric Fans
-Custom Dyno-Tuning
-2600 stall
-3.73 gears
-slicks
Originally Posted by 99silveradoSS
Just Wondering. With the pullies available for the radix, how much boost would the smallest one put out on a 6.0?
A stock 6.0 with a 2.75 should be around 10-11 lbs of boost.
Originally Posted by Ripped427
A 2.75 is about the smallest you'll be able to run without belt slippage being an issue.
The smallest most people go with is the 3" pulley. This will give you another 3# of boost. You'll loose a little with the long tubes and free flowing exhaust so you should see about 8.5-9#. I'd be worried about detonation with anything more than this. I also consider 9# to be the safe limit but some people have run more than this on a stock motor with no problems.
Tom
Tom
Originally Posted by slimsoftball
I run the 3.0 pulley on my Magnacharged Silverado SS. My gauge shows just a hair over 8 lbs. I have had no problems as of yet.
There you have it folks!!!
Performance Trucks Sponsor
The 3" will work just fine. Before tuning, there was no detection of detonation, so no tuning is required.
I think you could get away with one size smaller and tuning, wonder how that would turn out, hmmm.
good luck,
allen
good luck,
allen
good luck,
allen
good luck,
allen
