How Many different coil packs
Old 03-23-2006, 03:05 PM
Fogle07's Avatar
Default How Many different coil packs
how many different coil packs are there for the 99+ trucks. i know there is one with the silver fins on the top and i got one right here in front of me without the fins. also i got another set of coils in yesterday that looks totally like nothing ive ever seen on a truck. im not sure if it is a truck coil or not waiting on the guy to get back to me.
Old 03-23-2006, 05:22 PM
03lowriderss's Avatar
i believe that all the lsx's use the same coil, and give next to nothing for hp
Old 03-23-2006, 05:25 PM
bigredexpress99's Avatar
no there are what I believe 4 different designs for the lsx engine....the round one on ls1/6's, the square ones on ls1'6's, the truck coils, and the new ones for the ls2. I dont know if the ls7's use a different coil, and about the ones with fins...can't say I've seen them....
Old 03-23-2006, 05:31 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
the ones with the fins on it are the truck ones I know cause they are like mine
Old 03-23-2006, 05:42 PM
Ok, I take that back....did a little quick research @ work.....there are 5 different coil design so far....The trucks all use the same coil 99-present, including the new tahoes, sclades...the camaro through 02 and vette through 04 use the same coils, and the gtos and cts-vs uses the same coils. Now your thinking where did I get 5? the trucks and gtos each have 2 different types....a mitsubishi coil and a delphi coil. and the ones with the heat sinks are the mitsu truck coils.
Delphi is round, mitsu is square.
here are the part numbers -
Truck-99-present -
12558693 (mitsubishi)
10457730 (delphi)
Gto/Cts-v/vette/Impala, Monte Carlo, Grand Prix w/5.3 05-present -
12570616 (mitsu)
12573190 (delphi)
Camaro, corvette, gto, cts-v up to '04 -
12558948 (only one!)
Maybe a sticky or something??
Old 03-23-2006, 06:14 PM
1slow01Z71's Avatar
Mine arent square looking though and they have the heat sinks
Old 03-23-2006, 06:54 PM
i stand corrected, thanks for that tid bit. ps why is there so many diferent styles,
Old 03-23-2006, 08:00 PM
KySilverado's Avatar
Those would be the Delphi units.
Old 03-23-2006, 08:37 PM
Fogle07's Avatar
then there must be 4 different truck coils? the fin ones in both mitsubishi and delphi and the ones without fins in delphi and mitsubishi. im working on a project and im just trying to figure out what all coil packs i need to get ahold of to take measurements off of.
Old 03-28-2006, 07:08 PM
well, maybe they changed the design, the part numbers for these coils change at least once for each of them, so there is either a supplier, price, design, or application change. bChalk it up to what you want, they all work the same and bolt up!!!
Quick Reply: How Many different coil packs
