how to log injector duty cycle
Old Mar 3, 2004 | 02:23 PM
BlownAlaskan's Avatar
Default how to log injector duty cycle
Roads are just starting to get dry up here and I am getting geared up to work on my tune. I have heard everyone talk about logging duty cycle and I am interested in this to see how my 44lb'ers are holding up and how much room I have left for a small shot of go go juice. There are so many different PIDs to choose from. Which ones do I want to log?
Old Mar 3, 2004 | 03:07 PM
BigTex's Avatar
Log the injector pusle width, it will be in milliseconds. You'll compare that to the total possible time between power stroke events for a given cylinder - thats two revolutions - at a given rpm.
Just divide 120 by whatever rpm you log your pulse width at then compare to you logged values.
Example - 60 seconds in a minute @ 6000 rpms gives you 10 milliseconds per revolution times two revs per power stroke = 20 milliseconds. So at 6000 rpms, you have a maximum time slice of 20 ms to fuel the cylinder. 60/(rpms)*2=120/rpms
My example:
I can log 23 ms pulse width at 6000 rpms, so my PCM is saying it needs 23 ms to supply the desired amount of fuel. 23 is 115% of 20, so I'm at 115% duty cycle and lean.
This means that the higher you spin and more power you make, the bigger the injector you'll need.
Old Mar 3, 2004 | 03:24 PM
so is there a generic injector pulse width PID, or is there a PID for each injector?
Then, how do you make the next connection from: "I'm at 115% duty cycle and lean," to: I need more injector, or I don't need more injector?
Thanks, TEX.
Old Mar 3, 2004 | 04:19 PM
BigTex's Avatar
EFI has a PID for injector pulse width, but I don't know its exact name right off hand.
If the total possible time to add fuel is 20 ms and you are logging a higher value, then you are out of injector. 23 / 20 = 115% - I was saying my PCM is commanding 15% more fuel per cylinder at 6000 rpms than my injectors can possibly flow.
Old Mar 3, 2004 | 04:45 PM
ok got it. Sorry for my stupidity. Thanks TEX
Old Mar 3, 2004 | 05:13 PM
parish8's Avatar
single digit dreamer
my efi live has an actual injector duty cycle pid to choose from.
i was at 108% with the stock injectors and with the 57's the most i have seen is 42%, got some room to grow there.
Old Mar 4, 2004 | 05:00 PM
INJDC% = INJBPW * RPM / 1200 (condensed version of the math Tex showed above)
Wow! 57lbs injectors are pretty big parish!
TX Tahoe Z71
Sep 1, 2015 09:11 PM
rojeho
Aug 8, 2015 07:20 PM
Sexyrado327
Aug 2, 2015 04:08 PM
fillpot
Jul 26, 2015 07:21 PM
jrplz
Jul 9, 2015 12:07 AM
