how to install Eaton Posi?
Old Jun 9, 2003 | 03:31 PM
KeukaZ71's Avatar
Default how to install Eaton Posi?
does anyone have a link that can be detailed enough to take me through the Eaton Posi installation? or you can give me detailed instructions on this thread. how hard is it? i want to know how to do it myself just in case i need to transfer it to a new vehicle. i have the bearings, shims, marking compound, and posi. i still need gasket and gear lube. anything i left out?
Old Jun 9, 2003 | 11:37 PM
RED2K's Avatar
Default Re: how to install Eaton Posi?
ttt
Old Jun 10, 2003 | 06:40 PM
KeukaZ71's Avatar
i guess no one has done this themselves
Old Jun 10, 2003 | 07:29 PM
IslandTahoe's Avatar
Check out randy's ring & pinion. They have some information for gear installation, basically what you are looking for.
Old Jun 10, 2003 | 08:18 PM
FILE's Avatar
Unless you are very mechanically inclined and have the tools, I would not dare try to install it myself. Just take it to reputalbe shop. A friend of mine is doing mine over the weekend for $75 and some beer.
File
Old Jun 10, 2003 | 08:20 PM
FILE's Avatar
axle seals
Old Jun 10, 2003 | 08:49 PM
KeukaZ71's Avatar
i did not hear anything about axle seals. i guess i will have to do some extensive research before i attempt this myself. don't you have to pull some of the axle? is this what the axle seals are for? i plan on running 85/140 as gear lube. anyone advise against that?
Old Jun 10, 2003 | 10:19 PM
FILE's Avatar
This should help you.
http://www.ring-pinion.com/tech.shtml
Dan Neumann
11
Aug 7, 2022 09:06 AM
Turk55
Sep 11, 2015 11:52 AM
mz00516
Aug 23, 2015 12:19 PM
Eddielerma
Aug 11, 2015 01:10 AM
