How to install dowel pins in block head?
I searched, surprisingly only found videos and posts on how to remove em if theyre stuck. One of my dowels came out when i pulled the old head gasket off. Doesnt seem to want to go back in easily. Figured id ask here is there a proper was to install the dowel back in? Its a 2013 LC9 5.3
Big chamfer side "UP"
Tap it in with a brass mallet, or since youre not likely to have one, a rubber mallet will do it too, but will suffer damage
You can you a ball peen and a brass blivet to do it too. Don't hit the dowel with anything hard. Soft materials only, it'll pop back in
2013AvalancheLC9 (09-24-2021)
Had this happen to me, used a rubber mallet but bought new dowel pins. I think I had lost them in the head
They're a VERY LIGHT press fit. Might be able to push em in with your finger.
I usually use a BFH, very gently, padded with a block of wood. Hardly even takes a tap, let alone a whap or a full beatdown.
The following 2 users liked this post by TXsilverado:
arthursc2 (09-30-2021),
Mark Johnson (10-08-2021)
