need head gasket advice
Old Oct 4, 2009 | 11:51 AM
jow02327's Avatar
Default need head gasket advice
I am running cometic head gaskets right now and last night i "pooched" a head gasket. I had thought that cometics were the better gaskets but i noticed alot of FI people are running stock head gaskets. Anyway i want to know what you guys think i should do. Should i go back with cometics or back to stock head gaskets?
Thank in advance,
Jed
Old Oct 4, 2009 | 01:18 PM
06chevy5.3's Avatar
I thought they where better too.. I would check the deck of the block and heads for low spots where the gasket blew
or maybe they just gave you a bad gasket
Old Oct 5, 2009 | 08:00 AM
Rick_Vor's Avatar
If you look at a lot of the high HP guys around here and LS1Tech, you see a lot of people running either head the Gm 5 layer MLs or the Cometics.
I would take a wild guess that the head gasket wasn't the issue. 13lbs isn't all that high so I think if it wasn't an overheating issue, I would look into your tune and have the deck and head surfaces checked for flatness.
Rick
Old Oct 5, 2009 | 08:43 AM
jow02327's Avatar
13psi is all that it would make on the dyno, it makes more like 16psi on the street/strip. I'm having a hard time figuring out why it happened because I'm running arp head studs also. I'll check the block and head surfaces when I get the head pulled off tho.
Old Oct 5, 2009 | 09:35 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
A lot of us run GM MLS gaskets but with ARP J19 head studs, which allow us to over-torque the heads by 15 or so ft/lbs. *DO NOT* over-torque with bolts or other head studs.
The MLS gaskets are really pretty good pieces. With proper conditioning and installation, they last forever.
When I pulled BRT apart, the gaskets were perfect, despite big boost and about 10000 miles and 3 years of service (the heads had been over-torqued for the same period).
Last I looked into them, Cometics required extra installation steps, that if not followed could lead to failure. Now, that that with a grain of salt, because I've never installed or run cometics.
Old Oct 10, 2009 | 03:19 AM
$nake Charmer's Avatar
I just blew my head gaskets a couple of days ago but the wee the 3 layer gm gaskets and they were also for a 5.3 bore lol yeah don't ask Im not sure who excactly did that but anyways... I'm going to run th 5 layer MLS gaskets after I have my heads and deck resurfaced.
Old Oct 10, 2009 | 04:33 AM
Derek @ EDO's Avatar
FormerVendor
Get you a set of stockers and call it a day. They are proven and dont require a finer RA (roughness average) like other aftermarket brands.
Old Oct 10, 2009 | 03:16 PM
jow02327's Avatar
thanks, that's what i was thinking about doing. Should i spray them with copper spray before i put them on?
Old Oct 11, 2009 | 05:28 AM
I AM A MOTHERF*CKER
Yes -- both sides
Old Oct 11, 2009 | 07:00 AM
exodus's Avatar
What does this do?.....I was always under the impression that you never put anything on a set of head gaskets.
