How to hook up elec. fans to PCM?
Old Feb 12, 2004 | 10:08 AM
F8L Z71's Avatar
Default How to hook up elec. fans to PCM?
I really dont wanna have to use a a temp control switch for my electric fans and would like to run em off the PCM like in my F and Y bodies. Is there a diagram floating around that shows how to hook em up or anyone who knows the correct wires out of the PCM (pin #s) that I need to splice into?
I assume our trucks dont have the temp sensor in the heads like the F-bods do so I can easily get a sensor to make this work. Is this what you guys do?
Old Feb 12, 2004 | 10:25 AM
Scream's Avatar
MOOBIES Moderator
I wanna know too! I saw that you can unlock this feature in the truck PCM when messing around with EDIT. I would love to wire mine up so the PCM would control them.
Old Feb 12, 2004 | 10:41 AM
BlownChevy's Avatar
blownerator
25 Year Member
You will need a pig tail to start with, I have them if you need it! Just e-mail me.
After you get the pig tail you will install it into pin number 42 on the blue PCM connecetor under your hood. This wire will now send out a negative and will be used as the trigger on your relay to turn on the fans. The biggest problem will be if you dont have LS1 Edit, this will be needed to activate the fan switch.
Here are a couple of post links to help:
http://james.jaguar.net/agreif/fans/fanstech.htm
http://www.ls1truck.com/howto/pcmfan...ng_frames.html
I have them hooked up to my PCM and it is the BEST!
Old Feb 12, 2004 | 03:21 PM
F8L Z71's Avatar
Awesome!
Thx man. I have access to all kinds of molex plugs (pigtails) so if you could describe it to me I'm sure I can get something to work.
I have Edit so it should be a breeze. I have edit on all 3 of my cars so I know how the fan functions work so 1/2 the struggle is over
Old Feb 12, 2004 | 04:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sounds like you are on the way! The pig tails are the OEM wires that I pulled out of a wrecked truck. If you need them just send me a self addressed stamped envelope to the shop and I will send a couple to ya.
Project R
9940 Canoga # 106
Chatsworth, CA 91311
Old Feb 12, 2004 | 05:52 PM
ThunderZ28's Avatar
12 Second Club
Project R
9940 Canoga # 106
how much BLOWNCHEVY for the pig tail?
shipped to 77571
Old Feb 12, 2004 | 06:38 PM
Is running the fans with the PCm better? what do you mean by pigtails. Pics please.
Old Feb 12, 2004 | 08:23 PM
BlownChevy's Avatar
blownerator
25 Year Member
Running them with the PCM is better and cleaner IMO!!
I will take some pics and post them soon.
If you guys need the pig tails I have some.....just send me a self addressed stamped envelope and I will drop them in the mail for ya!!
Old Feb 12, 2004 | 09:13 PM
FILE's Avatar
Here is a pic of mine controlled by the pcm.
Old Feb 12, 2004 | 09:44 PM
Looks Clean
