How to get ASP Crank Pully off?
Old Dec 21, 2006 | 05:15 PM
14 Second Truck Club
Default How to get ASP Crank Pully off?
The three jaw-puller won't get around to the back and their isn't any holes in the front or anything.
Old Dec 21, 2006 | 05:17 PM
TouchOfEvil04's Avatar
I had to use a oversized one to get mine off. Much larger than the 3jaw but only works if the engine is out of the truck.Thats how we got mine off.
Old Dec 22, 2006 | 04:59 AM
Do you know what size? I even rented a 2/3 jaw puller and haven't had luck with it yet. The motor is out, trying to put it on the new one.
Old Dec 22, 2006 | 11:34 AM
slowec's Avatar
There is a special puller for those. Go to the local chevy dealer and try to smooze a technician into loaning it to you. Unless your close to me ... I'd loan ya one.
Old Dec 22, 2006 | 11:37 AM
ColtSteele's Avatar
i had an asp on mine before i put the ati super damper on. it was a bitch to get off- we actually screwed it up pretty bad getting it off, ended up tossing it. good luck
Old Dec 22, 2006 | 11:41 AM
the ASP charlie and I installed at 3 holes in the front just like the old school pulleys
Old Dec 22, 2006 | 12:00 PM
Nick™'s Avatar
yeah, you can use the old pulley pullers that have the three bolts that screw into those holes. Make sure the bolts are grade 8, I've seen them break and if one breaks off your pretty f'ed
Old Dec 22, 2006 | 05:23 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I used a regular 3jaw puller on mine and pulled on the out edge its fine.
Old Dec 22, 2006 | 07:31 PM
That's what sucks, it doesn't have any holes. Just solid.
Old Dec 22, 2006 | 07:32 PM
Really? I had thought about doing it like that but was scared that it would bend.
