How to fill transfercase?
Old Jul 3, 2003 | 10:29 PM
Hit Man X's Avatar
Default How to fill transfercase?
Okay...laughing aside, the fill plug is about 4" above and to the right of the drain plug on an Autotrac case right?
Well I can't seem to get more than about half a quart in the transfer case.
Is there some trick to filling the case up? Maybe a fill hole elsewhere?
Thanks!
Old Jul 3, 2003 | 11:01 PM
Black Blown 02's Avatar
Default Re: How to fill transfercase?
Go get a pump from an auto parts store. They make one that fits right on a quart bottle.
Old Jul 4, 2003 | 08:30 AM
parish8's Avatar
single digit dreamer
i use a nozle from a gear lube bottle and just put it on the tranny oil bottle, stick it in the hole and squeeze. when the oil starts running out it is full.
Old Jul 4, 2003 | 07:13 PM
Hit Man X's Avatar
I have a gear oil filler on there, I squirt it in and just goes everywhere...
Is there a vent tube that maybe plugged?
Old Jul 4, 2003 | 07:17 PM
parish8's Avatar
if you stick that gear filler tip on there and it comes right back out it must be full, can you look in there with a flashlight?
Old Jul 4, 2003 | 08:15 PM
Hit Man X's Avatar
I know it is not full as I drained 2 qts out and only could get 1/2 of a qt in. The only thing I can think of I must not be getting it completly in the hole...like I am hitting the side of the hole with the fluid and that is why it keeps coming out. I did peep inside with a flashlight and could barely see in there.
I have decided to just say screw it, and get the trans place to finish filling it up along with installing the servos. I can't drive it anyway right now.
Anyway, thanks for you help man...I appreciate it!
Old Aug 20, 2004 | 09:08 PM
Mort's Avatar
Try looking in there with a flashlight and a mirror. Maybe there is a gear or something right in front of the fill hole. Maybe if you hold the hose at a different angle it will help keep it from running back out. I just put a gear oil top on the transfer case fluid bottle and filled mine that way. It was a bit awkward but it worked. I think that I had a short piece of clear hose on the end of the gear oil top as well but maybe that was for the front diff which was even harder to fill if I remember correctly.
Old Aug 20, 2004 | 09:16 PM
moregrip's Avatar
what a rush!
Thanks!
Dude, your back!!!
If you want I can read my service manual and see what it says......
Chavette
Oct 28, 2015 07:33 PM
dantheman1540
Sep 15, 2015 08:28 PM
97aztecgt
Sep 10, 2015 05:07 PM
mayko
Sep 7, 2015 12:24 PM
