How far can stock injectors go?
Like the subject heading says.. How much power can the stock injectors support?
What size are stock on a 4.8/5.3 I believe the two motors have the same injectors and the 6.0 jumps up in size a little.
The 6.0 has the same injector. In fact, my SS has the same injector as the 4.8 and 5.3.
N/A, I think mid 300s are possible, but that depends on how many rpms you plan on turning it. If you have a good sized cam and turn 6500 rpms, the stock injectors will probably run you lean on the top side. FI or dry nitrous, I would keep to a moderate amount and under 6K rpms.
GrooveCityZ71
Aug 31, 2015 12:05 PM
maxspeed05V
Jul 19, 2015 07:08 PM
