How do you guys launch?
Old Jan 6, 2003 | 10:38 AM
MarineBlue03GMC's Avatar
Tech Fanatic
Default How do you guys launch?
How do you guys launch when racing your auto trannies?
I have a 03 GMC auto tranny 5.3 with 3.73s and the factory locker.
Anyway I am trying to figure out wether to launch in a lower gear, use the brake while gassing it, or just stomping on the gas.
Should I leave traction control on or off?
Anyway I would really appreciate the info. I want to find out the best way to get some low times.
Thanks!
Old Jan 6, 2003 | 11:10 AM
Scream's Avatar
MOOBIES Moderator
Default Re: How do you guys launch?
I have some pretty crappy 60' times, but it's mainly b/c of the dog-leg rear end and low profile 20's. I'm assuming that you're running factory tires?
I have to launch off idle. I come up against the convertor as little as possible--no more than 600 rpms--or the truck just annihilates the tires! I roll into the throttle and go. I launch in OD...manually selecting 1st won't make the truck launch any harder. Also, I've found that the tow/haul mode should be left disengaged.
I would think that you could get better times with the traction control off, but try it both ways and see which is best for you and your driving style. You never know...
Old Jan 6, 2003 | 01:02 PM
BigKID's Avatar
It all depends on where I am racing and what the traction conditions are. At a good preped track I can stall up around 1200 and nail it. Other wise I just preload the suspension a bit (around 800rpm) and roll into the throttle. Otherwise it is just a smoke show.
Old Jan 7, 2003 | 12:34 AM
CHAGO's Avatar
AUTO 4WD <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
