How do you guys dent headers? What's your preferred method?
Old Aug 23, 2009 | 09:43 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by phasemaster1
Wow John wouldnt expect you to use a torch. Im sure if you had to do it a long burnout would get those headers cherry red then take the hammer to it...
DICK hahaha
One thing I do, do is things right..
Umm I didn't realize they were coated.. I wouldn't do that then. I would more then likely mark the are that needed to be massaged and remove them to do it in this case..
phasemaster1's Avatar
Yes sir should do the trick.
Old Aug 23, 2009 | 09:54 PM
hirdlej's Avatar
What's the worse that could happen if I hurt the coating in that area, will the rest of the coating around that primary fall off?
Old Aug 23, 2009 | 10:02 PM
GMCtrk's Avatar
It would be more of an aesthetic issue than anything, but it wont hurt anything. And it won't completely remove the coating, so it will not rust. Personally, I would pull the header and do it. It will be more precise, and with only 5 inches to work with, I doubt you will generate enough force to make a good dent.
Old Aug 23, 2009 | 10:08 PM
Baltimore Whore
If infact the coating starts to peel in one area, all it takes is moisture to get in it, bam your **** will start to peel. I bet on it...
Old Aug 24, 2009 | 07:05 AM
03 BLACKOUTSSS's Avatar
Also, if the coating peels so close to your clutch, that will be a hot spot in the primary and MAY cause the clutch material to get hotter than normal. Could cause clutch issues in the future, but that may be a bit of a stretch.
I would pull the header and, heat, ding, heat, ding, heat, ding until its good. Its a PITA, but you know thats the right way to do it.
Old Aug 24, 2009 | 12:19 PM
Spoolin's Avatar
GFYS and STFU
If the clutch is already out take it to a local machine shop and have them put a bend in the clutch pedal and forget the headers.
BKnBLK05
Dec 28, 2015 08:52 PM
Onetogofast
Jul 27, 2015 08:33 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
