how cold is too cold?
Old Jan 24, 2005 | 08:19 PM
parish8's Avatar
single digit dreamer
yes, i am using a wideband. unless it is misreporting i am at 11.8-1 on every run no matter what temp.
Old Jan 24, 2005 | 08:29 PM
You are running 11.8-1 but the density of the supercooled air is greater causing the lean condition.With this condition on a carburated setup you would encounter a icing condition that would eventually cause the motor to stall.
Old Jan 24, 2005 | 08:33 PM
parish8's Avatar
i am not running lean, ever. cold or hot my a/f ratio is dead nuts on. it was pasing more air when cold(and fuel of course). but wasn't much if any quicker.
Old Jan 24, 2005 | 08:39 PM
Yellowsierra's Avatar
Do you think the extra fuel and air is raising the compression ratio? I dont know this is just crazy. I'm affriad to drive my truck out in the cold now
ronn25's Avatar
I kind of see what Whitt1 is saying, even though you a/f ratio is dead on, at 10 degrees your getting into extreme low temps. The air has so much more oxygen you may need to richen it up more than what works well in normally operating temps???
Old Jan 24, 2005 | 08:43 PM
i have no idea wtf you guys are talking about!
Old Jan 24, 2005 | 08:45 PM
Yeah maybe 11.8/1 is the ideal A/f ratio normally but with it that cold maybe you need more like 11/1 A/F ratio.
Old Jan 24, 2005 | 08:46 PM
moregrip's Avatar
what a rush!
Pfm
Old Jan 24, 2005 | 08:50 PM
parish8's Avatar
well, that could be, dont really know what the best a/f ratio is at 10deg.
Old Jan 24, 2005 | 08:57 PM
Are you going to change the A/F ratio if it gets that cold again just to see what happens? Maybe alittle bit richer than normal is all it needs? I don't know. If you do try it post your results. Thanks
