How choppy/noticable of a idle should i have?
Old Feb 22, 2005 | 11:25 PM
Stroker 1500's Avatar
Default How choppy/noticable of a idle should i have?
Ok, i really expected to have a choppy idle with my cam. I bought a cam off of a member of this board who said it was a lt4 hot cam. The specs are :
The duration at lash point in degrees (intake/exhaust) is 279/287; duration at .050" tappet lift (intake/exhaust) is 218/228; and maximum lift with 1.6 rocker ratio (intake/exhaust) is 525/525. Valve lash is zero/zero and lobe centerline is 112 degrees.
Now on every cam clip i have heard with similar duration has a real distinct choppy idle.. Mine sounds a hair more agressive then stock at idle but not much at all. The only difference between the cam clips i have heard and my setup is i have a 383 instead of a 350, would that be enough of a difference in engine size to tone it down? im just really confused because its not quite what i expected.. Also if it was the wrong cam my fuel trims would be off wouldn't they (got a mail order tune and gave them those cam specs) I got the cam from Fabricator on the board
Old Feb 23, 2005 | 01:13 AM
CAMMIN03''s Avatar
Banned
It should.... Your lift it a little bigger than mine.... my duration was 212-218-522-529-114
You can definently tell theres a cam in there.... but only with the cut-out open.... with it closed it has the slightest lope.... I think on a 112 it should thump pretty good...IMOP
Old Feb 23, 2005 | 01:26 AM
Hmmm, my idle is set at 750 and im running magnaflows with cats, so maybe thats part of the reason.. It sounds more crisp then idle but is still pretty smooth.. I mean most people question that i have a cam in it
Old Feb 23, 2005 | 01:29 AM
Deckhand's Avatar
I have the LS1 hotcam in mine, http://mail.streetfire.net/ViewShare...4-A7B4CA3B8069
Old Feb 23, 2005 | 01:31 AM
Originally Posted by Deckhand
Thats what i expected mine to sound like... But then again that is on a 4.8 and im close to a 6.3 so im not sure how big that plays into it
Old Feb 23, 2005 | 01:38 AM
2MuchRiceMakesMeSick's Avatar
Whats your idle set at? You could always turn it down for more chop.
Old Feb 23, 2005 | 01:40 AM
I did, it didn't seem to change it much, other than it fealt like **** to drive
Old Feb 23, 2005 | 02:32 AM
Yelo's Avatar
a 383 will eat an LT4 Hotcam right up.....it's almost the same as putting an agressive cam in a 5.3 and 6.0...the 5.3 will idle choppy but the 6.0 will idle ALOT smoother, the extra cubes REALLY kill a choppy idle
Old Feb 23, 2005 | 10:21 AM
Kano's Avatar
you can also back off the timing at idle
and itll idle rougher
Old Feb 23, 2005 | 10:24 AM
Kano's Avatar
I have cats and magnaflows and it takes alot of the lope from mine
