how to check motor?
Old Apr 30, 2004 | 09:45 PM
dubrado's Avatar
Default how to check motor?
I wanna check to see if the motor is solid...its not in the truck yet, but I wanna make sure it's not fuxored, what can i do?
leakdown test?
Old Apr 30, 2004 | 09:49 PM
Have you rebuilt it yet? I wouldn't put any engine in my truck that I didn't hand rebuild myself.
Old Apr 30, 2004 | 11:30 PM
HAZE's Avatar
cylinder compression, pull the heads check the valves. but unless you tear it down you won't know how the crank, bearings, guides,block, so on and so on are. do you know it's history, wondering if it's not rebuilt or a new long block why it's not still in a truck ? unless the motor in your truck now is totally shot i can't see dropping something questionable in it's place. in other words, rebuild it, and while your at it build it. if you run it and something goes, it will cost you more later.
Old May 1, 2004 | 01:51 AM
LOW2000's Avatar
Theres all kinds of tests you can run on a bare block, magnafluxing, ultrasonic testing, pressure testing, you name it. Its almost impossible to do a compression test on an uninstalled engine, so a leakdown is about the only other thing you could do. You can also take a look at the oil to make sure there is no coolant in it, and if there is and the head gaskets are good, then you're looking at a crack somewhere.
Stainless Works
Apr 10, 2016 04:34 PM
TXsilverado
Nov 26, 2015 10:54 AM
chevyl33
Aug 24, 2015 08:21 AM
Stainless Works
Aug 4, 2015 12:56 PM
jmarkway
Jul 18, 2015 09:23 PM
