How is this cam?
I called Comp Cams today and they suggested this cam for my 5.3HO.
Its a custom grind.
218-224 at .50
605-600
112
The specs of my truck are in my sig, Am I able to run that much lift and not have piston to valve problems?
Can someone give me a guess on HP with the mods I have done?
Thanks Mitch.
Its a custom grind.
218-224 at .50
605-600
112
Thanks Mitch.
You'll be absolutely fine. Valve lift has no effect on piston to valve clearance. Duration DOES. You're nowhere near the neighborhood of PTV interference with the cam you listed above.
lawhitediamante
Aug 12, 2015 12:14 PM
