How is this cam?
Old Jan 29, 2009 | 07:39 PM
GREENSIERRA's Avatar
Default How is this cam?
I called Comp Cams today and they suggested this cam for my 5.3HO.
Its a custom grind.
218-224 at .50
605-600
112
The specs of my truck are in my sig, Am I able to run that much lift and not have piston to valve problems?
Can someone give me a guess on HP with the mods I have done?
Thanks Mitch.
Old Jan 29, 2009 | 08:13 PM
GMCtrk's Avatar
I believe it is always recommended to check PTV at the time of installation, especially since you have flat top pistons.
Old Jan 29, 2009 | 08:33 PM
hirdlej's Avatar
You'll be absolutely fine. Valve lift has no effect on piston to valve clearance. Duration DOES. You're nowhere near the neighborhood of PTV interference with the cam you listed above.
Old Jan 29, 2009 | 08:34 PM
hirdlej's Avatar
If you want to wait until this spring I'll have a cam near those specs for sale with only 2K miles on it. Until then my truck is in storage.
Old Jan 29, 2009 | 08:41 PM
GMCtrk's Avatar
supposed specs
I may be interested in that cam come spring if indeed it is what it's claimed to be.
Old Jan 29, 2009 | 08:45 PM
Thanks for the responses guys.
Do you guys have a estimate on HP with my setup?
Old Jan 29, 2009 | 09:55 PM
hirdlej's Avatar
My 218/224 .562/.581 114 LSA +4 will be for sale come April
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
