How to build an exhaust resonator tube to eliminate drone
#61
That's kinda what I was wondering about. I used 8 cylinders. So maybe it doubles since I'm running the resonators before the crossover, and its only seeing pulses from one bank? Not sure how I'd fit 58" resonator tubes under there.
#62
As I understand it this resonator is mounted B4 the Y- pipe and is on one(4 cylinders) side then 'd say the remedy is to add a resonator to the other side. Yes- it makes a difference...………...
#63
Resonator configurations
So far, in all 1/4 wave resonator solutions I have seen, the resonator is mounted at 90 degrees on the exhaust pipes. I know that it does not matter if the resonator has a (soft) bend, but what if the resonator is mounted at a different angle on the exhaust pipes?
See the two configurations on this photo. I wonder if version 1 (my preference) has the same effect as version 2?
Thanks for your insights!
Finn
Finn
#64
Built one of these this weekend and I am very pleased with the results. Targeted drone at 1,500rpm which happened to be right at 100hz and according to this spreadsheet I found I needed a pipe length of about 42".
https://drive.google.com/file/d/1PYy...Khr5lE-_9/view
#65
What muffler is that?
#67
Pretty cool, thought it looked a bit bigger and was just curious lol
#69
Thinking about swapping mufflers after the headers depending on how it sounds. Just looking at what everyone else is running
