How to build an exhaust resonator tube to eliminate drone
Old Aug 16, 2019 | 03:55 PM
  #61
Donmaximo's Avatar
That's kinda what I was wondering about. I used 8 cylinders. So maybe it doubles since I'm running the resonators before the crossover, and its only seeing pulses from one bank? Not sure how I'd fit 58" resonator tubes under there.
Old Sep 12, 2019 | 12:25 PM
  #62
Mark Johnson's Avatar
As I understand it this resonator is mounted B4 the Y- pipe and is on one(4 cylinders) side then 'd say the remedy is to add a resonator to the other side. Yes- it makes a difference...………...
Old Nov 14, 2020 | 08:04 AM
  #63
Finnray's Avatar
Registered User
Lightbulb Resonator configurations
So far, in all 1/4 wave resonator solutions I have seen, the resonator is mounted at 90 degrees on the exhaust pipes. I know that it does not matter if the resonator has a (soft) bend, but what if the resonator is mounted at a different angle on the exhaust pipes?
See the two configurations on this photo. I wonder if version 1 (my preference) has the same effect as version 2?
Thanks for your insights!
Finn
Old Jul 19, 2021 | 07:51 AM
  #64
dantheman1540's Avatar
Built one of these this weekend and I am very pleased with the results. Targeted drone at 1,500rpm which happened to be right at 100hz and according to this spreadsheet I found I needed a pipe length of about 42".
https://drive.google.com/file/d/1PYy...Khr5lE-_9/view
Old Jul 19, 2021 | 08:01 AM
  #65
shakenfake's Avatar
Shlumpt
5 Year Member
What muffler is that?
Old Jul 19, 2021 | 08:06 AM
  #66
It's an OEM muffler off select year dodge rams with a Cummins and 4" tail pipe.
Amazon Amazon
Old Jul 19, 2021 | 08:11 AM
  #67
shakenfake's Avatar
Shlumpt
5 Year Member
Pretty cool, thought it looked a bit bigger and was just curious lol
Old Jul 19, 2021 | 08:20 AM
  #68
It helps more than I thought it would, there are very limited options for 4" stuff.
Old Jul 19, 2021 | 08:30 AM
  #69
shakenfake's Avatar
Shlumpt
5 Year Member
Thinking about swapping mufflers after the headers depending on how it sounds. Just looking at what everyone else is running
Old Jul 19, 2021 | 08:36 AM
  #70
I highly advise one of these 1/4 wave resonator pipes if you have a lot of drone.
