Home Depot'd my CAI and dropped my IAT 20 degrees!
Old May 31, 2009 | 09:30 AM
Truckshop's Avatar
Originally Posted by SUX2BU
People need to stop believing everything they read and experience stuff first hand.Did it in my SS and after 70k miles i pulled the motor apart and it looked perfect! no signs of oil sludge.
Plus, I have my 40k GVW tranny cooler on the way, a PT3200 stall in a 6,000 lb truck that sees 95% stop and go traffic and my A/C is always blasting. After i took my thermostat out my driving around town engine temps went from 210* to 190*(The 210 was with a 160* thermostat in it.). I live in Texas and have three big coolers/condenser in front of my radiator. So the air it does get has already been heated up a good amount.
If i ever notice the engine not getting up to operating temp when it cools down outside I'll throw a 160* in it. Takes a whole 10 min.
correct. your temps let it get hot enough not to sludge. this is not what i have read it is experience.
Old May 31, 2009 | 09:51 AM
SUX2BU's Avatar
11.0 Moderator
The SS ran at about 140-160 at the absolute hottest.
Old May 31, 2009 | 10:55 AM
Noah Burns's Avatar
sux... didn't the first motor in that SS blow up??
Old May 31, 2009 | 11:06 AM
zapata41's Avatar
why do ppl think they need to run the motors soooo cold, you get a cleaner burn when the motor is a little hotter, burns out the carbon in the fuel better. ppl running 160 stats to richen up the mixture or to prevent detonation need to tune better.
Old May 31, 2009 | 03:59 PM
viciousknid's Avatar
Where's the Beef?
You want low IAT's but the engine doesn't need to be under 180. If it's too cold your MPG's will drop because it'll be running too rich unless you changed your tune to lean out sooner.
For those in emission states, the higher temps allow it to burn better and reduce emissions. Don't know how much of a difference it would make but it could help some people pass emissions if they are running too cold.
Old May 31, 2009 | 04:57 PM
skolman91's Avatar
good idea, not so much on the looks, but hey whatever works..
Old May 31, 2009 | 07:35 PM
JoeGibbSilverado's Avatar
i run a 160, truck runs 180-200, nice idea on the intake
Old May 31, 2009 | 08:03 PM
budhayes3's Avatar
PT's Slowest Truck
I've seen engines overheat because the t-stat was removed...what happens is you remove a restriction that's figured into the cooling system design, and coolant is now flowing faster than it used to, and it doesn't get a chance to be in the radiator long enough for it to be cooled off. Not saying that it happens every time, but it is a possibility under the right conditions.
The CAI set up looks effective though :thumbs:
Old May 31, 2009 | 09:17 PM
SUX2BU's Avatar
11.0 Moderator
Yeah, taking out the thermostat caused my fuel filter to clog and #7 to detonate and take a chunk out of the ring land.
Who is you since you know so much about me? A secret admirer maybe?
Old May 31, 2009 | 09:18 PM
SUX2BU's Avatar
11.0 Moderator
My truck doesn't run that cold and if it does I'll put a modded thermostat back in it.
