Home Depot'd my CAI and dropped my IAT 20 degrees!
Old May 31, 2009 | 09:23 PM
  #21
SUX2BU's Avatar
11.0 Moderator
I've seen engines overheat because the t-stat was removed...what happens is you remove a restriction that's figured into the cooling system design, and coolant is now flowing faster than it used to, and it doesn't get a chance to be in the radiator long enough for it to be cooled off. Not saying that it happens every time, but it is a possibility under the right conditions.
The CAI set up looks effective though :thumbs:
LOL at people believing that water has to sit in the radiator to cool off.
Old May 31, 2009 | 09:41 PM
  #22
sonoma43's Avatar
The water does have to be in the radiator for more than 10 seconds to cool off though....the coolant will not cool off by flowing through the raditor in a rapid rate under certain conditions.
Old May 31, 2009 | 09:47 PM
  #23
budhayes3's Avatar
PT's Slowest Truck
That's where the largest heat transfer in the cooling system occurs
Not to mention that I've known a few guys in the past who have removed their t-stats, thinking it would be a performance gain, just to have their cars/trucks overheat....coincidence?
Old May 31, 2009 | 09:53 PM
  #24
GMCtrk's Avatar
It sounds like removing the thermostat is analogous to endotoxic shock causing a high output heart failure. lol.
Bud, this is the first time I've seen you confrontational in a post! Congrats! Make sure those eyeballs don't roll back into your head
Old May 31, 2009 | 10:01 PM
  #25
SUX2BU's Avatar
11.0 Moderator
Come on man, 10 seconds? So does the air going through the radiator have to pass by it slow so it can pull the heat out of it? LOL.
Old May 31, 2009 | 10:04 PM
  #26
SUX2BU's Avatar
11.0 Moderator
I'm sure you knowing a few guys trumps me personally doing this to some of the cars I've worked on (including my own) and them all running cooler. Is this a great idea for all cars? Nope. But it's worked in the cars i've done it to that had cooling problems.
Old May 31, 2009 | 10:11 PM
  #27
budhayes3's Avatar
PT's Slowest Truck
Air is a gas and has different physical properties than engine coolant...my best guess. I just know from 1 guy with a mid 80's Caprice (305 sbc), 1 66 Mustang, straight six, and a few other sbc's that I've seen, removing the t-stat=radiator overflow boiling over, steam under hood, and temp gauge pinned.
Old May 31, 2009 | 10:13 PM
  #28
budhayes3's Avatar
PT's Slowest Truck
I did it to my own 71 Camaro when I had overheating problems...it got me through until I fixed the actual problem. Like you said, it's different for different vehicles with different cooling systems...if it works for you, go with it
Old May 31, 2009 | 10:21 PM
  #29
Wilde Racing's Avatar
How do I change this text
100%, correct might not effect everyone in every weather condition...
Old May 31, 2009 | 10:27 PM
  #30
SUX2BU's Avatar
11.0 Moderator
Yeah i like to try stuff out for myself. I find you learn a lot more that way.
