The Holy Grail.............
Old Sep 17, 2007 | 09:51 AM
Mark Johnson's Avatar
Default The Holy Grail.............
Well guys, I've found it, my search is over. I've settled on a camshaft; thru alotta hemming and hawing and what not, I still wnated to stay kinda small for torque and towing sake. It's a Comp Cams XR259HR which specs out at 206/212 - .515/.522 on 112 LSA. Man I'm so jizzed! I always wanted a tighter LSA and that 112 is just perfect! Well I be OK with the Yellow LS6 valve springs?
Thanks again for puttin' up with me, guys, like I said B4- takes awhile for the light to go on...................
Old Sep 17, 2007 | 10:18 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Sounds like a good cam for your application. Nothing wrong with spending time to make such an important decision.
What will you do for tuning once installed?
Old Sep 17, 2007 | 10:29 AM
BlackGMC's Avatar
Resident Retard
Moddo runs that cam.
Old Sep 17, 2007 | 10:41 AM
I have HP Tuners................
Old Sep 17, 2007 | 12:41 PM
Moddoo's Avatar
I don't know, that's a really small cam, you probably won't even notice a difference
Congrats on the choice.
I hope you like it as much as I do.
The yellow springs are plenty. I have been running them for 30K+
Old Sep 17, 2007 | 12:56 PM
What about pushrods? I understand that the stockers flex like a ****.........
Old Sep 17, 2007 | 06:11 PM
nightrunner's Avatar
Mr. Obvious
any hardened ones, COMP, thunder, TSP just to name a few
Old Sep 17, 2007 | 06:44 PM
dirt track racer 81's Avatar
comp 212 218 cam is a damn good cam also for low end power..i have a 230/226 cam in my 6.0 and i tow my race car (12,000lbs altogether) with a 3200 stall it and pulls like a ****..
Old Sep 17, 2007 | 08:02 PM
Yeah- I'm beginning to realize that you can have yer cake and eat it too with these LSx engines. The fact of the tight LAS causes the valve events to occur faster, or closer together which helps retain or even enhance to llow end while add to the midrange and some top as well. Damn this is getting good............
Old Sep 17, 2007 | 09:44 PM
03 BLACKOUTSSS's Avatar
Originally Posted by 2001c3driver
Man I'm so jizzed!...............
Congrats on the choice, but "jizzed"
no need to go that route
JFWY, hope you like it.
