Holley ls valve covers on truck pcv valve
Old Feb 29, 2016 | 09:09 AM
bisqikss's Avatar
you need to install an inline pcv valve. go to holley website and pull up the instructions for the valve covers. it will give you two choices of brands for the inline pcv valve. I think it was beck arnley and fram iirc. If you don't, you will pull a lot of oil into the intake or your catch can.
Old Mar 1, 2016 | 12:07 PM
darkirish63's Avatar
I have these on my motor - you'll need to run a fixed orifice pcv and I would suggest a catch can as well. Just put it in line between the valve and the intake. I can post a pic if needed.
Old Mar 1, 2016 | 09:32 PM
Slammed silverado's Avatar
Thank you guys
Old Mar 2, 2016 | 05:24 AM
03sierraslt's Avatar
Some coil info I found.
Old Jul 26, 2016 | 10:23 PM
BigEd_72455's Avatar
You mean these coils? the stock truck coils? The one's pictured came off an 04 Silverado 4.8. I have some from an 01 Yukon that bolt right up also because they are identical.
Old Jul 27, 2016 | 07:56 AM
Some of the truck coils have a different bolt spacing, majority will work. The coils pictured above by biged have the standard bolt spacing so they work.
Old Jul 30, 2016 | 10:17 AM
Can you provide part numbers for the pictured coils? Are the MSD any hotter spark than the stock ones?
Old Jul 30, 2016 | 10:22 AM
COPIED FROM HOLLEY Valve cover manual:
NOTE: Some applications, as pictured below, have internal PCV restrictions inside the cover assembly. If your application utilizes this type of connection, an external PCV valve must be added in-line on the hose. If needed, suggested PCV valves are: (1) Beck/Arnley P/N 0450299 or (2) Fram P/N FV340.
jtphelps289
Mar 21, 2016 11:16 AM
parks450
Feb 19, 2016 01:51 PM
NHolds
Feb 19, 2016 01:37 PM
TAPyvehc93
Feb 15, 2016 09:35 PM
