Holley Hi-Ram Fuel Crossover Fittings
Old 04-04-2015, 09:18 PM
slammedsam's Avatar
Default Holley Hi-Ram Fuel Crossover Fittings
Hello I am not sure if this belongs in this section or not, but I am gathering parts for my lq4 build and have heard that the fuel crossover fitting is kind of tight on the front of the driverside fuel rail. I have searched every where I could think of but never found any definitive answers, so if anyone has some input, pictures or part numbers it would be greatly appreciated! I am planning on using -8 fittings on the rails. Thanks Sam!
Old 04-04-2015, 09:20 PM
Three6GMC's Avatar
They sell a very low profile -8 90 fitting that works great... let me get a pic and all the info. You can't get any more low profile then this fitting as it only sticks out a hair more then the width of a -8 nut fitting.
http://jimcoracingcomponents.com/col...ra-low-profile
Old 04-05-2015, 04:02 PM
slammedsam's Avatar
Holy crap thats expensive! I'm not paying $55 for one fitting if I don't have to, Any one else have any input? I just read a little more after thinking my oem feed was -8 and they are actually closer to -6. But the fuel rails say they are threaded for -8 orb. So can I go -6 to the fpr, then -8 from regulator to rails? I have an aem 320 in tank, and 42lb injectors. The current setup will be nitrous up to 700~rwhp, with plans to go boosted in the future and hopefully hit 1000rwhp. I have read that if I do run -8 from the pump I can use the original feed as my return. But then how does all that work with stock fuel bucket etc, this is my first FI build so I need some guidance with all of this. Thanks Sam
Old 04-06-2015, 09:45 PM
slammedsam's Avatar
bump. any other options?
Old 04-07-2015, 07:36 PM
1TRUESS's Avatar
Earl's Performance AN to Straight Cut O-Ring Fittings AT949068ERL - Free Shipping on Orders Over $99 at Summit Racing
Way cheaper!
This is what I will be running, plumbing it up this weekend!
Old 04-07-2015, 08:58 PM
Three6GMC's Avatar
Post pics of that Earls fitting when you get everything installed.
Old 04-07-2015, 10:38 PM
I have a gauge for that
Atomic's Avatar
The short radius one I used had about this much clearance behind a 145a alt after trimming the plastic.
Pretty sure it was only available in silver so I spray painted it black
Old 04-08-2015, 09:41 AM
slammedsam's Avatar
I think i'm going to try this one Fragola Performance Systems Radius AN to O-Ring Adapters 499208-BL - Free Shipping on Orders Over $99 at Summit Racing . And post some pics of yours installed 1TRUESS!
Old 04-08-2015, 10:32 AM
1TRUESS's Avatar
I will do! I might even have time tonight to mock it up for pics if I get off work a good time.
Old 04-08-2015, 03:59 PM
1TRUESS's Avatar
I have an easy 5/8" of room, but keep in mind that is an 105A alternator and a -8 0-ring to a -6 line. I hope this helps!?
That fitting only sticks out an inch from the end of the fuel rail, but with -6 straight hose end add another 1/4" to that..
Quick Reply: Holley Hi-Ram Fuel Crossover Fittings
