HMMM am i on the right track...
Old Dec 30, 2007 | 02:33 PM
foxls1's Avatar
Default HMMM am i on the right track...
I noticed that on my 08 1500 4.8 the cam sensor seems to be up front (can someone verify this) . if this is true, cant i use an Ls2 cam and slide right in and no probs???(new springs of course.)
Old Dec 30, 2007 | 03:27 PM
Truckshop's Avatar
if the sensor is up front then yes. the only other thing is depending on what year cam the sprocket could be a single bolt or the regular 3 bolt. if yours is a single bolt then you would also need a 3 bolt sprocket. i have a ls2 cam from a tbss if you are interested. yellow spring also.
Old Dec 30, 2007 | 03:39 PM
foxls1's Avatar
what specs? so if my sprocket is a 1 bolt, i will need the 3 bolt sproket to use ur ss cam? where can i get this sproket
Old Dec 30, 2007 | 03:56 PM
Truckshop's Avatar
205/211 116 + 3 .525 lift you can get the cam sprocket on ebay or your local dealer.
Hpinnovate
Sep 4, 2015 02:28 AM
LSX-81-SIERRA
Aug 31, 2015 05:52 PM
low_life96
Feb 7, 2008 07:22 PM
Code Red
Nov 14, 2005 08:41 PM
Code Red
Nov 14, 2005 03:53 PM
