High Performance 8.1
Old Aug 11, 2004 | 10:37 PM
miket's Avatar
Thumbs up High Performance 8.1
Who's got the baddest---let me know what your running and what you think your HP numbers are.
Old Aug 12, 2004 | 09:12 AM
tbyrne's Avatar
See signiture
2002 8.1 Silverado HD - Full Throttle lift, 37" tires, 4.56 gears, Comp Cam, TOG headers, Volant induction plus more! Heads, cam and intake manifold upgrade coming soon!
2002 8.1 Suburban -Intercooled Whipple supercharger, 22" wheels/tires + more - 407hp/558 ft-lb torque at the rear wheels - 13.93 @ 95.79 MPH
www.tbyrnemotorsports.com
Old Aug 12, 2004 | 04:05 PM
04LS1GTO's Avatar
I have seen the Burban run and it gets my vote
Old Aug 12, 2004 | 07:40 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
2002 8.1 Avalanche 2500, tuning, cold air kit, custom exhaust. 310hp/470ft-lbs
Next week.......cam and NX wet kit!
Old Aug 12, 2004 | 07:51 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I would loooo-ooo-oove to see a 13 second suburban!
Old Aug 13, 2004 | 12:00 PM
TieRod's Avatar
K/N intake, ported TB, MSD wire, HPP III, TOG headers, custom 3" exhaust, Comp Cam xr270 that 8100hammer now has, and NX wet kit 200HP.
322hp, 433tq with go gas 504hp, 640tq.
Best et in sig.
Old Aug 13, 2004 | 12:02 PM
Black Blown 02's Avatar
Best et in sig.
Nice time! what was your 60'?
Old Aug 13, 2004 | 06:55 PM
1BADAZZSS's Avatar
1.74 60's ft
Old Aug 13, 2004 | 09:44 PM
Will See after the 29 of august what the cam will do, my tune for cam is finally on its way(if it is good). But fast time to date is 15.42@87.5 60'-2.109 for a stock truck with cold air and pcm tune. Coming soon 1.8 Rocker Arms My E-fan kit, long tube headers, and Bully dog Allison shift enchancer. With that should put me deep into the 440hp at the crank.
Old Aug 14, 2004 | 09:20 AM
tbyrne's Avatar
It's good to see some other modified 8.1s!
I'm also going to install a set of long tubes if I can get them in before the heads, cam and manifold is swapped. They come with a 2.5" collector to tie into the factory head pipes but they can be made with something larger for a custom exhaust.
