High oil pressure
Started the truck up today to drive home from work and I noticed the oil pressure was pegged. This morning pressure was normal. I switched my scangauge to watch it digitally and at idle pressure was ~100psi when I got on the road it was around 116-118 psi cruising. I just parked it when I got home and didn't drain the oil because I had a busy afternoon. I'll pull the plug and see what kinda of material I see in the oil and on the magnet this weekend
Would the pressure sender lose calibration like that, or do I have a more serious problem? Pulling the plug will tell me more but I just wanted to prob people for other possibilities in the meantime.
How do I change this text
Stock sending unit is behind the intake. I've never replaced one with the engine in the truck but I would say it would be hard to do without pulling the intake off. You could test pressure there as well, or the oil cooler block on the side of the engine, but that will require drilling and taping.
NM, think I found it: GM 12562267, ACD D1818A
Rock Auto showed a different part for regular cabs though for my '01 5.3L: GM 89057526, ACD D8037
Anyone know the difference between the two? The second one didn't have any hits on here or LS1tech.
superchomper2003
Aug 26, 2015 09:39 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
