High oil pressure????
Old Jan 5, 2005 | 07:09 PM
paw's Avatar
paw
Default High oil pressure???? HELP!!!
I went on 3k mile trip in my truck a couple weeks ago. Now that i'm back, I noticed today that my oil pressure is higher than it used to be. It was right at 80 at WOT before the trip. Now its its at 85 at WOT, almost all the way to the end of the meter! I also notice less power.
What has happened? Is there a problem. I had the oil changed when I got home.
HELP!!
Old Jan 5, 2005 | 08:09 PM
paw's Avatar
paw
Some one help me, please...
Old Jan 5, 2005 | 08:29 PM
NateZ's Avatar
It started to do this before or after the oil change?
Nate
Old Jan 5, 2005 | 08:34 PM
Just check the oil level to make sure it is not overfilled. Mine has always hung around 60 psi at idle, and would peg the end of the meter at WOT.
Old Jan 5, 2005 | 10:36 PM
paw's Avatar
paw
It was doing this before the oil change, after as well...
Old Jan 5, 2005 | 10:59 PM
user 108208932024's Avatar
Banned
At WOT in my dad's 04 Silvy 5.3 it would peg the 80. It read middle of the dipstick but pressure was kinda high. I wouldnt be to worried about it, if it worries you then don't put as much oil in next change.
Old Jan 6, 2005 | 05:59 AM
one03sierra's Avatar
Formerly one92rs
Talking
did you say a loss in power? 85 is a bit much imo. but hey mine pegs 80 at wot. if it is at the right level then it should be ok. drive it some and see what it does.
Old Jan 6, 2005 | 06:14 AM
L-EATER's Avatar
11 Second Truck Club
I had that happen to me in a LT1 once and it ended up being a cam bearing that spun in its bore and partially blocked off the hole. I tried a new oil pump first since that was the easiest but then it still did it. I drove it a long time like that before we finally fixed it.
Old Jan 6, 2005 | 01:20 PM
04BlackGmc's Avatar
10 Second Club
So 80 at WOT is normal i was wondering that today when driving.
Old Jan 6, 2005 | 03:08 PM
KRISZ7104's Avatar
Ye I have noticed that mine will do that to at WOT. Mostly though when the engine is not quite up to operating temperature...
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
