Hi-temp engine coating...(rattlecan)
Old Aug 26, 2009 | 10:42 PM
sc_customs's Avatar
Default Hi-temp engine coating...(rattlecan)
Worth it? I bought a set of pacesetters non-coated and was debating.
Old Aug 26, 2009 | 11:06 PM
L7 Sierra's Avatar
I will last a bit but it always burns off again. Its not thick enough and most importantly annoying.
You have to sand them completely.
Clean them completely
spray them with 4 coats
then in-stall them and start the motor to bake on the coating. In less then 3 hours after you paint.
I recomend a test fit first to see where you can go wrong if at all.
Old Aug 26, 2009 | 11:07 PM
L7 Sierra's Avatar
They work great on motors, trannys, accesories, but not headers
Old Aug 26, 2009 | 11:14 PM
RandomHero's Avatar
I'm tempted to try some of the coatings POR-15 sell. They have some that are rated from 1200* up. I haven't checked to see how hot turbo parts get, but that seems like a pretty big number.
Old Aug 27, 2009 | 01:13 AM
Spoolin's Avatar
GFYS and STFU
I just bought a can of this today and it claims to be used on headers and withstand up to 2000 degrees...
I'm not planning on coating my headers but if I take them off again I might!
Old Aug 27, 2009 | 01:14 AM
Spoolin's Avatar
GFYS and STFU
Depending on your tune it can get to 1800-2000 degrees if your really rich. None of which is good.
Old Aug 27, 2009 | 01:55 AM
sc_customs's Avatar
that's what they have at autozone (checkers i think elsewhere?) I know the dupont stuff didn't hold up on my buddies truck but i figured this might be different
Old Aug 27, 2009 | 07:25 AM
Coban's Avatar
To get the paint to stick right surface prep will be most important.
With high-temp coatings, the thinner the better. Even then, it won't last forever.
superchomper2003
Aug 26, 2015 09:39 AM
nrmskate
Aug 11, 2015 02:44 PM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
