Here is my exhaust setup
Old Mar 10, 2006 | 10:10 AM
agreif's Avatar
Default Here is my exhaust setup
Ok guys, here is what I am thinking for my exhaust setup. Getting rid of the flowmaster and replacing it with a magnaflow pretty much all new exhaust. Need to keep my cats too for inspections. Since my stock exhaust is 2.5"OD, I figured I'd stick with that vs going with the 3". All this will go along with an updated Nelson tune for a Comp Cams XTREME RPM HIGH LIFT XR265HR (54-424-11) - 212/218 - .558/.563 115 LSA. Much thanks to Kenny (BigKid) for showing me how he did his, it gave me some great ideas.
Whatcha think?
Andrew
Old Mar 10, 2006 | 11:15 AM
blksilverado's Avatar
looks like a good set up. still tryin to decide what i want to do also. not to hijack ur thread but i have thought about getting pacesetter LT and 3" in/out cats, instead of the reducer for more room between the crossmember. Then run 3" piping to an x-pipe and then the muffs. using 2.5 tailpipes.. however i think the 3" piping is a little overkill for my setup. i just want to get away with not having to use reducers. your setup is prolly the best way to go, are you gonna use a turndown or a tip.
Old Mar 10, 2006 | 02:23 PM
agreif's Avatar
I thought about going with the 3" pipes too. But when I got under my truck all the stock piping was 2.5" for my 4.8. I figured if I went to 3" it wouldn't be too bad, but keeping with the stock size would probably be best. I have to use at least one reducer at the Y pipe as the Y pipe for the 3" inlets went to a 3.5" outlet, which I would reduce down to the 3 in/out muffler like you were talking about.
Old Mar 10, 2006 | 02:24 PM
zippy's Avatar
looks about right to me.
GXPJAY
Feb 13, 2022 08:15 AM
brandon6.0
Aug 19, 2015 07:48 AM
06 4.8
Aug 16, 2015 06:16 PM
askkmb
Jul 18, 2015 09:02 PM
Mark_k
Jul 8, 2015 10:44 PM
