HELP! WHat would YOU do?!?
Old Mar 2, 2012 | 05:53 PM
  #31
dmelvin's Avatar
You could get a set of 243s and put on the LS1 and basically have a LS6?
Different pistons, and cam, and intake, but otherwise... basically yes.
Originally Posted by TXSZ66AVLANCHE
Oven cleaner? Lol berrymans B12 at any parts store works awesome on old gunk n stuff. I cleaned up 220K nasty valve covers to looking new in 2 min.
The parts store that I go to doesn't... and it's the only parts store in 30 miles
  #32
Beatdown Z's Avatar
Laid Back
Mill the 317's and put them on the LS1, done!
Old Mar 2, 2012 | 07:40 PM
  #33
JKearney30's Avatar
Yes I coils for everything, caddy motor, camaro motor, and the original 5.3l truck coils and accessories. Basically my garage is full of a ton of stuff for these motors its just a matter of setting up and going.
Old Mar 3, 2012 | 08:24 AM
  #34
JKearney30's Avatar
I have another question, probably dumb but oh well. What computer do I need to use for each vehicle? I have a total of 3 computers, the stock camaro LS1, the caddy 6.0L, and the truck stock 5.3L computer. Since I am putting the 6.0 in the camaro and the camaro 5.7 in the truck, which vehicle uses what computer? Thanks again
Old Mar 3, 2012 | 08:36 AM
  #35
Beatdown Z's Avatar
Laid Back
use the computers that are original to the vehicles
Old Mar 3, 2012 | 01:11 PM
  #36
JKearney30's Avatar
OK I am going to get the heads milled down, should I go with .030 and then use stock gaskets or what gaskets do I use?
Old Mar 4, 2012 | 01:14 AM
  #37
Beatdown Z's Avatar
Laid Back
I'd go .040" and use some stock MLS gaskets made for the LS1 bore size, so you don't lose any compression.
Old Mar 4, 2012 | 11:01 AM
  #38
JKearney30's Avatar
OK, another stupid questions, which head bolts do I use on each motor? The LS1 heads used different head bolts then the 6.0 heads.
Old Mar 4, 2012 | 01:48 PM
  #39
oakley6575's Avatar
Do some searching and figure out if .040" is safe to do on these heads. I'm not sure how much you can go without intake fitment issues.
Old Mar 4, 2012 | 04:10 PM
  #40
Beatdown Z's Avatar
Laid Back
Plenty of guys go .050"+, so i'm sure .040" would be fine. Just don't forget to check pushrod length or take the easy way out and order some 7.360" rods.
With the headbolt issue, you're talking about the LS1 having the long headbolts and the 6.0 having the short ones, right?
You need to match the headbolts to the blocks. The heads are the same. You can pick up some head studs off ebay or just order some replacments from rockauto/parts store.
