HELP! WHat would YOU do?!?
Old Mar 2, 2012 | 12:18 PM
oakley6575's Avatar
It's his daily driver. If you are worried about the drop in compression, just have the heads milled. Your not looking to make a lot of power with the truck right? Thats what the camaro is for.
Old Mar 2, 2012 | 12:34 PM
TXSZ66AVLANCHE's Avatar
To answer question of the OP you can use the LS1 in the truck, use the truck intake, acc drive, and truck harness. 806 heads are perimeter bolt valve cover, honestly I'd throw em away and buy a set of 853 or 241 heads, $150 per set on ebay is pretty common.
Old Mar 2, 2012 | 01:03 PM
JKearney30's Avatar
You wouldn't use the 317s on the LS1? What if I throw a cam in there, I have a gm performance hot cam that I had in the 5.3 that was in the truck laying around, would that help if i used the 317s?
Old Mar 2, 2012 | 01:13 PM
Cam won't make up the compression loss. If it were my engine I would not use the 317's on the LS1, and the hot cam is horrible with the stock converter.
Old Mar 2, 2012 | 01:16 PM
dmelvin's Avatar
On the subject, I have a set of 241 heads with springs I'd sell you. They're off of an LS1, came with the motor when I bought it and I'm not going to reuse them. I'm going to clean them up with some simple green and oven cleaner tonight and take some pictures.
PM me if interested.
Old Mar 2, 2012 | 01:48 PM
Oven cleaner? Lol berrymans B12 at any parts store works awesome on old gunk n stuff. I cleaned up 220K nasty valve covers to looking new in 2 min.
Old Mar 2, 2012 | 02:55 PM
JKearney30's Avatar
Well I have the truck yank tt3000 converter that I used with the 5.3 but i really dont wanna cam the truck anyways, its going to be towing my vehicles and boat. (Very rare occasions but still.) What would the 241's do for me as far as compression?
Old Mar 2, 2012 | 03:12 PM
JKearney30's Avatar
Another question, what motor makes more power completely stock 5.7 or 6.0 and which is easier to build and make more power in long run. Why is 6.0L better then 5.7, I know it has bigger bore and larger rods and stuff but does it being iron block and heavier make it worse in anyway?
Old Mar 2, 2012 | 03:50 PM
oakley6575's Avatar
I really don't understand all the fuss on the compression. Spend the $45 to mill the heads and be done with it.
It all depends on what you want out of the vehicles. I thought the goal with the truck was reliable daily driver, and the camaro was the weekend warrior..?
Old Mar 2, 2012 | 03:51 PM
Both use the same identical rods with a 3.622 stroke. LS1 with 241 heads is 10.3 and LQ4 with 317 heads is 9.5, both in stock configuration make almost identical power.
