HELP!!!! Truck will not attempt to start! only means of transportation
Old Nov 1, 2010 | 05:24 PM
  #21
nickleahy23's Avatar
fun stuff isnt it? I just put a new starter in mine, and the ****** turns over on its own..no keys in, no relay in etc..connect the battery and it turns and turns...thanks for a shitty starter advance..
Old Nov 1, 2010 | 06:00 PM
  #22
viciousknid's Avatar
Where's the Beef?
Not being smart but did you make sure the hot and remote wires on the starter aren't touching?
Old Nov 1, 2010 | 06:13 PM
  #23
ya everything is just as it was before...i have no idea what it could be besides a shitty reman...im takin it back tomorrow and gonna try another one...
Old Nov 2, 2010 | 08:20 PM
  #24
WetChicken's Avatar
Originally Posted by marlboroman71818
Yeah tried all the stuff with the PN switch, it reads fine also. Checked the switch underneath to make sure connection was good.
Try starting it in all gears in case something slipped.
Be sure to hold your foot on the brake.
Old Nov 24, 2010 | 06:08 PM
  #25
TomSh's Avatar
Any updtae on the no crank problem? I have a 2007 NBS 2500HD with the exact same symptoms. Swapped the starter relay with others and it did nothing. Pulled the starter and cleaned all connections. Happened once when cold, and a few times after running for 20 + miles. After about 30 minutes it started. I do noticed a delay when turning the key to starter engagement. The truck only has 28K miles so I would not think the ignition switch or key would be at fault. Just ordered the Helm shop manuals to get a schmetic of the circuits.
Tom
Old Nov 24, 2010 | 10:45 PM
  #26
CashDudeHomie's Avatar
The 2003+ do have a slight delay when turning the key compared to the 99-02s. It feels more like a start-by-wire instead of the ignition being directly connected.
I short circuited my starter wires when I installed my long tubes way back in the day and blew out one of the large fuses 3 times before I figured it out
Yours is likely something else if it is intermittent.
Old Nov 24, 2010 | 11:58 PM
  #27
Atomic's Avatar
I have a gauge for that
I think there is a half second priming delay to let the pump build pressure, but dont hold me to that...
ferrellrooster
Mar 6, 2025 03:22 PM
OHsixLS3
Dec 27, 2016 09:30 AM
wrb002
Aug 31, 2015 12:00 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
