help! timing chain question
Old Jul 27, 2007 | 11:07 PM
00stepsyde's Avatar
Default help! timing chain question
I am in the middle of a cam swap, I put the new cam in, and the timing gear, but the chain just looks really loose, it has about 3/4 to an inch of slop in it, should I get a new timing chain while I am here or is that about right. If I need a new one what should I up-grade to quickly. I have to have this thing together by Monday. Thanks.
Old Jul 27, 2007 | 11:13 PM
Rhino79's Avatar
9 Second Club
Sounds normal, they run loose on one side, seen it several times.
truckmann's Avatar
Not sure how much slack is normal, but I would upgrade to an LS2 timing chain while you are in there. Should be available at most dealers part # 12586482
Old Jul 27, 2007 | 11:23 PM
silveradokidd_4518's Avatar
i just installed my LS2 timing set on my engine today and its got a decent amount of slack. thats about norm
Old Jul 27, 2007 | 11:28 PM
mwalls54's Avatar
Need More N2O Mod
how many miles do you have on that chain? if you have more than 30k I would go ahead and put a new chain on it while you are there. never hurts. and there is some slack in it when its in place.
Old Jul 28, 2007 | 10:41 AM
Yogi Bear's Avatar
About a half an inch of slack is normal, 1" is too much. Chains are cheap. Get a new LS2 chain.
Old Jul 28, 2007 | 06:24 PM
xlcooplx's Avatar
do you have to drop the front of the pan when replacing chains?
Old Jul 28, 2007 | 06:37 PM
truckmann's Avatar
Yes... It needs to be dropped just enough to get the bolt for the oil pickup tube out so the oil pump can be removed.
Old Jul 31, 2007 | 10:09 PM
Bad Dad 1's Avatar
Hey Guy's,
I didn't want to start a new thread... hope to get a reply/help on this.
I'm doing a cam swap soon, and I ordered a LS2 timing chain and figured it would come with new sprockets, but it didn't -- can I reuse the original 5.3 sprockets?
Thanks in advance,
Tone
Old Jul 31, 2007 | 10:14 PM
truckmann's Avatar
Originally Posted by Bad Dad 1
Hey Guy's,
Thanks in advance,
Tone
Yes!
