Help! time for new cats
Old Dec 10, 2009 | 11:46 AM
budhayes3's Avatar
PT's Slowest Truck
Since you're in CA, are you running manifolds or shorties, and do you have to smog every year? If you don't mind doing the work, you could get some LT's and either a catted or off road y-pipe, and swap em out when you have to smog. Does CA have the spot smog checks that I believe they used to have? If so, you might be in trouble there too
Old Dec 10, 2009 | 11:56 PM
laynlow77's Avatar
i have thorleys on there right now with a catless y pipe into a single gibson muffler. its not too loud, but its very raspy and thats what i cant stand. one of my cats was on the way out so i figured this would be the easiest way around that.
it runs better with no cats, but im guessing it will run almost as good with new cats and ill be happy with the way it sounds again.
unless i should put a bullet in from of the muffler or something instead?
Old Dec 11, 2009 | 01:05 AM
budhayes3's Avatar
PT's Slowest Truck
The bullet will act as a resonator and should help with the rasp. You could also put resonators where the cats used to be (instead of the bullet), then it'll look somewhat legal
Old Dec 11, 2009 | 07:33 AM
D_reks{5.3}'s Avatar
If you want to look legal but still have the performance you had without cats there, Get you a set of these dummy cats, and then the bullet in front of your muffler to get rid of the rasp..
http://www.siliconeintakes.com/produ...1ecabc6be18d13
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
GXPJAY
Feb 13, 2022 08:15 AM
BIGD4504
Jul 28, 2015 11:46 AM
