HELP with Seafoam
Old Jul 22, 2005 | 12:21 AM
Default HELP with Seafoam
I have a 04 Avalanche and I am trying to use seafoam but the throttle body is the electronic one where i can not manually open it and the truck does not have a brake booster line that I can pour it through
Where else can I put it in intake?
Old Jul 22, 2005 | 12:40 AM
Through the PCV valve line on the back of the drivers side valve cover.
Old Jul 22, 2005 | 01:03 AM
1SlowHoe's Avatar
Destroyer of Transmissions
If you put the key to on (dont start) and press the gas pedal, doesn't the TB open? Maybe not but I thought it would. Have somebody sit in the seat and hold the pedal or use a brick. I may be full of , someone correct me.
Old Jul 22, 2005 | 11:08 AM
desTRUCKtive's Avatar
You can disconnect the brake booster line and pour it in through there and will clean your intake system. That is the way that I did mine.
Old Jul 22, 2005 | 12:20 PM
duwem's Avatar
I have heard various stories about sea foam on this forum....I would do some research on here before you dump it
Old Jul 22, 2005 | 01:11 PM
Dub Silverado's Avatar
The newer trucks dont have a standard brake booster with the vacuum line. It looks like it has a pump or something on it. I didnt believe it till i saw it either.
Old Jul 22, 2005 | 02:43 PM
TURBHOE's Avatar
if your truck isn't started and you take off the intake tube you can push the throttle body open with you hand. i wouldn't do it if it was started though
Pimpinpete
43
Dec 22, 2017 08:13 AM
Fast86z
Aug 23, 2015 12:35 AM
05GMC4.8
Aug 7, 2015 09:55 PM
bsgiffor
Jul 19, 2015 11:14 AM
04BlackSilverado
11
May 15, 2006 08:08 PM
