HELP!! p0068,p0120,p0220,p1526,p0106 and REP
Old Apr 25, 2009 | 04:39 PM
10 Second Club
Default HELP!! p0068,p0120,p0220,p1526,p0106 and REP
I posted in here and the diagnostics section to hopefully get a faster response..... so i got my cam/stall and tune on my truck done about two weeks ago. itys been driving flawlessly since then. i even took it to the track and made a few runs in it, still good. i drove it last night and parked it at a friends house. i wake up this morning to go start it and it goes into REP mode, and then the idle starts to climb up to 3k rpm and stays. i disconnected the battery twice and it wont clear it. i am also getting these codes:
p0068 maf/map sensor throttle pos, correlation
p0120 tps/pedal pos. sensor a circuit malfunction
p0220 tps/pedal pos. sensor switch b circuit malfunction
p1516 manf cntrl veh spd idle speed control aux input
p0106 map/baro ckt range/perf
i have no idea what is going on and its driving me crazy. any help will be greatly appreciated.
Old Apr 25, 2009 | 07:49 PM
budhayes3's Avatar
PT's Slowest Truck
Check the wiring going to the throttle body, the TPS in particular, might have a broken wire or an animal may have eaten through the harness. If that checks out OK, I'd be troubleshooting something wrong in the throttle body area from the sounds of those codes.
Old Apr 25, 2009 | 07:53 PM
10 Second Club
thanks i"ll start chasing the nwires back from there>>>its a DBW if that makes much difference
Old Apr 28, 2009 | 07:34 PM
S/C Z71's Avatar
Banned
Disconnecting the battery will not clear codes. Your TPS is toast.
Old Apr 29, 2009 | 01:23 AM
10 Second Club
well i changed out the TB and cleared the codes, truck fired up first try and runs great. upon inspection of the old TB it looks like the bottom half of the blade. i measured with a digital caliper and there is a .223" gap between the TB blade and the housing>>>how the **** did that happen?
06droppedcrew
Nov 17, 2015 10:56 PM
JCW
Sep 22, 2015 03:59 PM
whippledstepside
Sep 17, 2015 05:02 AM
black00chev
Jul 31, 2015 04:33 PM
FlowmasterMufflers
Jul 30, 2015 04:29 PM
