Help needed in choosing correct cam/heads for a blown 4.8
Old Nov 1, 2004 | 01:58 PM
Default Help needed in choosing correct cam/heads for a blown 4.8
I am trying to find the right cam and heads to use with my Procharged 4.8 @8lbs. I am also trying to decide whether I should port and polish the stock heads, or go with a set of aftermarket ones. Any help is sincerely appreciated.
*2002 Black RCSB 4.8L, Procharger P1SC@8lbs. w/3-core, BBK 80mm TB, ASM Headers, 2.5" straight pipes w/2 40 series flows, Westers tune, e-fans, built 4L60E w/transgo, Yank tt converter, Eaton posi, 4.10 gears, $12K in appearance/stereo junk*
Old Nov 1, 2004 | 02:02 PM
I personally would run the stock heads with a P&P job instead of shelling out the extra $ for new heads. on the cam I am not sure, but a call to a few serious ls1 shops like futral will cure that. How's the truck sound with no cats and the 40 series?
Old Nov 1, 2004 | 02:09 PM
Default Reply about sound
Thanks for the input. It sounds great without the cats and the 40 series. I used to have just a gibson cat-back and it is sure a step up from that. The Gibson set up sounded ok, but pretty hollow and sounded kinda crappy at high RPMs.
Old Nov 1, 2004 | 02:48 PM
cool, I run dual 1 chamber flows on my regular cab and I have lost to much lowend and their to loud for everyday driving.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
