HELP need fuel pump fast
Have an 02 Burban 5.3 4X4
Need to get a replacement fuel pump and fit it into the buckett...
I want to replace it as factory without buying the module.
I dont have a problem cuting the crazy straw fuel line and replacing with injection hose.
I do have a problem cutting the factory buckett.....
Need to get car back on the road ASAP ..
Thanks in advance
Thanks in advance
I believe you can use the Walboro GSS340M. I was able to use this pump in my 2000 Silvy without any modifications to the bucket. I think your Suburban has the same set-up. As long as you do not have a returnless fuel system (03 is 1st year used?), you can use this pump.
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
