Help For My 4.8
I Need To Know Some parts To Get My 4.8 Woke Up I Have Programed It With Hypertech And And A Cool Air Intake So Let Me Know What Else I Can Do,but dont have money to spend right now on a charger
https://www.performancetrucks.net/fo...hlight=boltons
it applies to your 4.8 too
btw, the search button at the top works wonders
remember to change to one heat range colder on the spark plugs and tell your tuner that you will be spraying n2o ( use n2o instead of NOS to avoid getting flamed, some are **** about that stuff) unless you are going to still use a programmer, then run the stock tune.
ok i sent that nelson performance a email and told them what i would be doing,im just getting this truck a lil faster so my ole lady can out run some of theses guys around here in town
put a little cam in it just to spruce things up a bit....a friend of mine just put a 198/209 2000 transam ls1 cam in his 4.8 ecsb and you can tell the difference you dont have to replace valve springs or anything for that cam...just install it
waste of time IMO
get a comp cam for better gains
legerwn
56
Nov 15, 2015 10:21 PM
