Help Me Read These Plugs
Old May 14, 2014 | 08:45 PM
jgreen-fsi's Avatar
Default Help Me Read These Plugs
Little background, 2008 Denali 6.2 AWD Magnuson TVS-1900, LS7 throttle body, 3.2 pulley, 7 pounds boost, LS9 cam, VVT delete, just Magnuson tune and TSP did the VVT delete. These were LS9 plugs, I believe ACDelco 41-104. It runs good for the most part. A little bit of a rough idle, which drives me crazy. I changed to NGK BR6EF plugs today. These only had a few thousand miles and are maybe two months old and put in when I put on the sc. Just hoping to get some insight from more experienced guys, any input would be great. I think my tune needs some work.
photo2-1_zps4d4ec67d.jpg?t=1400117723
Passenger side 2 at the bottom to 8 on the top
photo1_zps382f3536.jpg?t=1400117724
Driver side 1 at the bottom to 7 on top.
Please excuse the anti-sieze, I probably went a little heavy on it.
Old May 14, 2014 | 08:52 PM
FFDP's Avatar
Look pretty normal to me.
Maybe a little unburnt fuel, kinda see some soot but nothing huge in my eyes.
Old May 14, 2014 | 09:29 PM
Byrdman11's Avatar
Look safe. It rich but the hot plug is cleaning them off. A cooler plug will show a little more fuel.
Old May 14, 2014 | 09:40 PM
jgreen-fsi's Avatar
So should I step back up to stock heat range?
I appreciate the input.
Old May 14, 2014 | 09:54 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Unless you removed these plugs immediately after a WOT run, meaning turning the key off after you release the accelerator, there isn't much to tell about your tune by reading the plugs. Additionally, you need to cut the threads off so you can read it properly.
Old May 14, 2014 | 10:40 PM
jgreen-fsi's Avatar
Thats a little much for my purposes. It isn't a race truck. I just want to get rid of my rough idle. I was concerned about the black spots on the porcelain on random plugs. The tune is probably conservative from Magnuson. I would like my Denali mannerisms and a beast when I get on it.
walledition
Feb 24, 2026 03:27 PM
Tydriver
45
Oct 23, 2015 09:19 PM
akcooper9
Sep 13, 2015 04:50 PM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
