Help me out guys:whats diff btwn x and h pipe
Old Oct 10, 2004 | 09:37 PM
Default Help me out guys:whats diff btwn x and h pipe
like it says what are the differences between the two types of pipes. is one better than the other, or maybe for just certain applications. brainiacs help me out please
Old Oct 10, 2004 | 10:53 PM
Flyer's Avatar
An X pipe is when it looks like 2 exhaust pipes run together in the shape of an X. This is suppose to balance the exhaust pulses and makes them flow better.
The H pipe is something like a true dual setup with a pipe that goes from one pipe to the other, this is also called a balance tube. It's suppose to do about the same thing the H pipe is, but isn't as effecient supposedly.
Old Oct 10, 2004 | 11:38 PM
user 108208932024's Avatar
Banned
I would say go X pipe but I've heard it argued both ways.
Old Oct 11, 2004 | 08:31 AM
The H pipe balance tube was used when cars had dual pipes running down seperate side. It supposedly helps balance exhaust pulses. When done correctly it will make a little more power and I think make the exhaust a little quieter. The H pipe is simply a crossover pipe between the sides looking like an H. The X actually has the pipes cross thru each other, supposedly works better. It's not going to make a huge difference, I think a 5.0 mag did a test with a lot of H and X pipes years ago. I don't remember the power numbers being very different.
Our trucks stock Y pipe balances the pulses just like a X or H pipe would.
Old Oct 11, 2004 | 02:57 PM
do you really think that the stock ypipes balance the pulses well
Old Oct 11, 2004 | 04:34 PM
I'm not an exhaust expert, but if the H or X is designed to "balance" pulses. Then a Y 2-into-1 will definitly balance it, they become one exhaust. I'm not sure how much flow a stock y-pipe can handle, but it seems many guys with only minor mods report loss of low-end torque when going to true duals.
You might search or ask around, I've noticed a post recently where "bigbody" is looking for a stock y-pipe, sounds like he might have had duals but wants to go back to stock. The post is from yesterday titled "new y-pipe"
Old Oct 11, 2004 | 05:10 PM
ridered's Avatar
i have heard that if using a straight-through muffler to go with the X. I f you are using a baffled muffler to go with the H. They both promote 'positive' scavenging of exhaust pulses as they balance the two sides together.
Old Oct 11, 2004 | 05:52 PM
Midnight's Avatar
I have an X-pipe for sale if your interested, it came off an '02 silverado.
Old Oct 11, 2004 | 06:22 PM
thanks guys for your help. i dont want to lose my low end so i guess i wont do the x til i get more mods on here. thanks for saving me and my money guys
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
BlownHD
Oct 3, 2015 12:24 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
GM1697
Sep 28, 2015 08:28 PM
