help me with my ATI S/C i cant get the power i should be
Old May 24, 2005 | 08:38 AM
  #41
(Ken)-Blown-383 4x4's Avatar
Originally Posted by j4nash
when the truck is turned off it goes to 30 vac
Guage has to read ZERO when the engine is off.....
Old May 24, 2005 | 08:39 AM
  #42
i called ati today and they said that i could loss about 6psi of boost with my cam and headers.
Maybe .5 psi but no more than that....all of this is sounding BS to me!
Ken
Old May 24, 2005 | 10:58 AM
  #43
Chevmann99's Avatar
A little off topic but this thread got my curiosity up, so last night I went and revved up my truck in park and I can see 4psi of boost just revving it.... My kit is the 9psi, P1SC it's all stock on a stock internals 6.0L (except injectors and tune) no FMU. I wonder if there is something up with the blowoff valve, I am using the cheapo one that came with the kit, it's very simple and works good although it is a little crude. Can you disconnect it or remove it altogether?
FWIW - The first time I planted my foot after my install I blew the piping apart & had to drive a couple miles home with the down pipe from the blower wide open, if you have a leak it should be pretty obvious, that thing moves a lot of air.
Old May 24, 2005 | 12:34 PM
  #44
I am not using the pipe that came with the kit i have all custom pipe. i don't think i have a leak, because i would know it right away and the truck would hesitate. i know this because when we first put the kit on we did not get the pipe secured good around the MAF and the truck would hesitate and was acting funny and would die. so i don't think i have any more leaks.
Looks like i should be getting a few smaller pulleys to try at the end of the week.
Old May 24, 2005 | 04:52 PM
  #45
One thing that I have noticed is that ATI compressor is not screaming by any means, I can hear it when i get in to it but it just sounds like it really is not working very hard. Is this normal or maybe because my pulley is to big
Old May 24, 2005 | 05:00 PM
  #46
14 Second Truck Club
Two things that were said before. The gauge should read zero when the truck is off. Also, them telling you that you could lose that much boost is BS. 1-2 psi max I would guess.
Old May 24, 2005 | 05:22 PM
  #47
I don’t know how the gauge could have gone bad because it worked when the last guy took it out, but on the other had I am not sure how it could be hooked up wrong. The only thing I could see is that I am loosing boost somewhere but I am just not sure where I am loosing it. I know that I am not getting the boost that I should be because I don’t feel the power that I should be getting.
Old May 24, 2005 | 05:51 PM
  #48
lm7's Avatar
lm7
worst case start over i dont knwo if u did the install bu its fairly easy just wwork backwards and hopefully youll find it before the kit is all the way off...hows fuel? im just worried your running it dangerously lean. pull a plug and take a look at it..
Old May 24, 2005 | 11:43 PM
  #49
well i am going to go over everything again tomorrow night and if i still can't i will be putting a different pulley on
Old May 25, 2005 | 01:31 AM
  #50
GMCHammer's Avatar
11 Second Club
Well if you can't get it to work I bet it would look good bolted up to my truck. Hope you figure out what is wrong with that thing. I was expecting to see some track numbers by now.
