help me with my ATI S/C i cant get the power i should be
#42
Originally Posted by j4nash
i called ati today and they said that i could loss about 6psi of boost with my cam and headers.
Ken
#43
A little off topic but this thread got my curiosity up, so last night I went and revved up my truck in park and I can see 4psi of boost just revving it.... My kit is the 9psi, P1SC it's all stock on a stock internals 6.0L (except injectors and tune) no FMU. I wonder if there is something up with the blowoff valve, I am using the cheapo one that came with the kit, it's very simple and works good although it is a little crude. Can you disconnect it or remove it altogether?
FWIW - The first time I planted my foot after my install I blew the piping apart & had to drive a couple miles home with the down pipe from the blower wide open, if you have a leak it should be pretty obvious, that thing moves a lot of air.
#44
I am not using the pipe that came with the kit i have all custom pipe. i don't think i have a leak, because i would know it right away and the truck would hesitate. i know this because when we first put the kit on we did not get the pipe secured good around the MAF and the truck would hesitate and was acting funny and would die. so i don't think i have any more leaks.
Looks like i should be getting a few smaller pulleys to try at the end of the week.
#45
One thing that I have noticed is that ATI compressor is not screaming by any means, I can hear it when i get in to it but it just sounds like it really is not working very hard. Is this normal or maybe because my pulley is to big
#47
I don’t know how the gauge could have gone bad because it worked when the last guy took it out, but on the other had I am not sure how it could be hooked up wrong. The only thing I could see is that I am loosing boost somewhere but I am just not sure where I am loosing it. I know that I am not getting the boost that I should be because I don’t feel the power that I should be getting.
#48
worst case start over i dont knwo if u did the install bu its fairly easy just wwork backwards and hopefully youll find it before the kit is all the way off...hows fuel? im just worried your running it dangerously lean. pull a plug and take a look at it..
Hope you figure out what is wrong with that thing. I was expecting to see some track numbers by now.
