Help me mod my new Suburban...
I have a '03 Suburban 5.3 that I would like to add a few bolt ons to.
What do recommend first?
I would like to get a cat-back, but don't want to get too loud as this is the family hauler.
What should I look at next, HPP3/Predator, Fans, intake???
What about a converter? I pull a 7000lb trailer every weekend so I don't what to hurt driveability.
Skip the converter if you are pulling the trailer. A set of headers or nice catback would be good. A UPD or similar intake would be a good mod as well. I wouldn't mess with the HPP3/Predator or fans yet. Maybe do a mild cam to really pep it up.
Banned
yeah, what richard said!!! longtubes/or mids if you can find'em would be great...installed some list night on my truck and they helped a ton. a small cam like an 01/02 ls6 cam would probably be good BIGTEX has experience with the 01 ls6 cam and made pretty good power with it also.
I pull the trailer in OD w/ 3.73's no problem.
It only gets to 7000lbs when it is totally full, ususally closer to 5500.
I would like to go the exhaust, intake route.
What headers/catback combo do you recommend to keep the noise level down to bearable levels?
I don't want wide open Borla sounds while cruising on the highway for hours at a time.
I have an'03 Tahoe, with a custom intake, just do a search on my name it should pull it up, others have done the same, I think it is as good if not better than the K&N. I also have a proflow muffler that is a 3 inch in and dual 2.25 out, nice sound not to loud, but load enough to know it is a V8. I also have the Predator, and felt it made a pretty decent difference for the money, eliminated the torque management, and added a little peppiness on the shifts. I still plan on doing some more shift mods, due to the fact that I like clean, crisp and quick shifts. These mods a relatively easy and inexpensive. I want to give the vehicle a chance to "wear" a little in case I need the warranty, then I may make the cam change and do some other power enhancers. Just my .02.
You will not be disappointed in the quality, fit, finish, performance and especially the sound. I put a CORSA cat-back on my 01 Tahoe 5.3......I had it on my truck for 2 weeks before I told my wife that I had put it on.....She didn't really notice the difference. It is a little louder in the upper rpm's, but sounds stock while cruising.
If i were in your shoes this is what i would consider doing.Good quality set of 1 3/4long tubes,Any kind of catback will be noisy,i would only do it at the very end only if you feel like you needed more.A UPD intake and mild cam, i would take a hard look at this tuner as he has been getting major praise over on the pick-up truck.com forum and he was running a $100 discount if you had seen it on that forum.http://westers_garage.eidnet.org/Index2.htm
GM1697
Sep 9, 2015 01:52 PM
