Help make me fast
Old Sep 10, 2011 | 06:11 PM
  #31
Beatdown Z's Avatar
Laid Back
Originally Posted by andrew383
Id never buy a used converter...EVER..... JMHO
Werd... Running a used converter is a gamble. It's a gamble that I lost big on, as well as a few others on the forum.
My rules for buying used converters are only run them as is if they have less than 5k miles and came out of a perfectly working trans. If they have over 5K and/or came out of a trans that failed or was on it's way out, then send it out to be freshened up. I'll probably start buying new converters from now on... well maybe not.
Old Sep 15, 2011 | 01:24 PM
  #32
Jrluz14's Avatar
Got a Bullet Racing 218/222 .544/.544 113lsa cam which should be ok with my stock converter for now, PAC 1218s, Comp 7.4s, LS2 timing set, and LPP headers.
What should I do for the exhaust? Keep the true dual, use an X pipe, or use the Y and go single from there back? I here a lot of different opinions. I always though boost applications worked best with true dual/x pipe and NA is best with 3" Y.
Old Sep 15, 2011 | 05:29 PM
  #33
Beatdown Z's Avatar
Laid Back
My truck has a **** ton of torque with a 2-1/2" y-pipe to single 3", so that's what I'll recommend to you, especially since you're spinning an 80E with stock converter and all that weight of a 3/4 ton truck.
Old Sep 16, 2011 | 01:11 PM
  #34
Jrluz14's Avatar
Thanks for answering. I'm definitely going that route then. Should be pretty badass, still undecided about a muffler. Corsa would be my first choice, but they're too expensive. Probably just go with a Borla.
Old Oct 15, 2011 | 10:20 PM
  #35
Jrluz14's Avatar
Well, got all the parts installed and got it retuned. It's definitely a lot faster. It doesn't really start pulling hard until around 3800 though, which I thought on a 218/222 it'd pull lower. My next plans are to get some different tires on it and I NEED a converter really bad.
Old Nov 2, 2011 | 07:51 AM
  #36
Jrluz14's Avatar
Found some stock HD wheels. I'm planning on running some 265s and a 2/3 drop just so the truck sits better on this setup. Hopefully this makes a big difference going from 20" cast rims and 33x12.5 M/Ts to 16" aluminums and 265s. Then comes a stall converter. Not sure on a brand yet. PI, CircleD, or Yank. After that the 799s will be sent to Advanced Induction for resurfacing and p&p. Going to look into an intake to go with the head swap. Hopefully I can make low 14s maybe break into the high 13s.
silverstreak07
Jun 28, 2016 06:29 PM
jdb11386
Dec 3, 2015 09:34 PM
echoman
Aug 22, 2015 01:53 PM
08lambochevy
Aug 7, 2015 11:42 PM
abey15
Jul 13, 2015 02:20 PM
