Help make me fast
Old Apr 16, 2011 | 10:10 AM
Jrluz14's Avatar
Default Help make me fast
I've been reading a lot on this site and I'm a newbie to internal mods. I drive an 03 RCLB 2500HD 6.0 4wd on 33s and I'm looking for more power, enough to give cars and diesels around here a run for their money. The 6.0 was replaced last year with a reman with 100k warranty and I'm going to void the hell out of it but it's worth it to me. Currently I have a cat back, CAI, custom tune, and e fans. Planning on some lt headers into a single 3" soon but want some internals as well before I do that and get a re tune. The lq4 I got has a noisy lifter (tick tick tick) and I'd like to get rid of that. They can get me a new one for free but i dont see the point since im going to open it up and void the warranty anyway, plus i barely have 13k on this one. I'm looking to keep the budget around $600-$800 and can probably do that buying parts in the classifieds on here. Any suggestions?
Old Apr 16, 2011 | 11:31 AM
RibeiroBJJ's Avatar
Praise The Lowered
Get a 224 ish cam and some pac springs...then save up for some budget LT's and maybe 4.56 gears f/r......last I would get a converter/shift kit/ trans cooler....that ought to get you out of the way of some diesels
Old Apr 16, 2011 | 12:17 PM
05gmcsierra's Avatar
that should do the job.. ^^
Old Apr 17, 2011 | 08:30 AM
Jrluz14's Avatar
What are PAC spings?
Old Apr 17, 2011 | 10:14 AM
AndysC3's Avatar
its a brand of springs, check out texas speed, sponsor to the>>>, they have some nice cam packages that come with pretty much everything you need.
Old Apr 17, 2011 | 10:26 AM
Jrluz14's Avatar
Do you think that the cam and springs will get rid of that lifter tick I have?
Old Apr 17, 2011 | 10:41 AM
AndysC3's Avatar
if it is a bad lifter, the only thing that will fix it is a new lifter. Why not have that fixed under warranty, then start modding?
Old Apr 17, 2011 | 03:05 PM
beingblueeyes's Avatar
maybe its just me but i would buy some better heads and fix the lifter. then with any money left go from there
Old Apr 18, 2011 | 11:22 AM
Jrluz14's Avatar
They won't let the lifter be fixed, they want the entire engine replaced. They don't like people opening up their engines, it's stupid to replace the entire thing. Maybe I'll just gather all the parts and replace the entire thing and mid it while it's on the stand. It's just more work than what's necessary. Wish they'd just cut me a check for labor to replace the damn lifter, then I'd have some fun.
Old Apr 18, 2011 | 11:56 AM
Mangled03gmc's Avatar
Baltimore Whore
Are you sure it is a lifter tick?? Gm's are notorious for piston slap, which some people could confuse with a lifter.. On such a small budget, that will get you a cam, rods, springs, with a couple bucks left over.. Next you need a converter, gears. Them 3 will make a big big difference... The cam alone, esp in the 224 duration range, is still going to leave more to be desired on the low end..
